Serial 6000 : the stove's output, the pleasure of an open fire
archiexpo
12. August 2008
These new stove with a panoramic view brings together society and harmony of volumes. Its hexagonal shape allows to install it as a wall-mounted or corner appliance with a minimal let. It has the advantage to be able to burn logs of 50 cm.Close the door to one of these stoves, and your room will instantly fill with a comfortable warmth. Everything is done for a high output : reinforced insulation, tight seals, optimal combustion, steel conduction, high performance fire-proof bricks.Open the door and you will be in direct contact with the fire, which is placed just above the log storage, it will remind you of traditional open fires.Standard equipment Metal double back insulation, ceramic prismatic glass resists to 800°C, log storage under the appliance, inside casing made of high performance fire-proof bricks (exclusive design by Don-Bar),design appliance grid made of welded steel, flue damper, primary airflow, secondary airflow.
Weiterlesen...
