archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Balmoral septic tanks are moulded in one piece corrosion resistant polyethylene. This construction ensures a very tough impact resistant and leak proof tank which is fitted with sturdy lifting eyes for easy handling and installation. The tanks are designed to accommodate drain invert depths to 1m. However, the neck can be easily cut down to suit shallower invert levels. The pedestrian duty lockable manhole cover is also manufactured in rotationally moulded polyethylene making it lightweight and easy to handle. In addition a safety grill is available to comply fully with statutory regulations and HSE recommendations. Balmoral septic tanks incorporate a unique patented baffle system which not only gives exceptional effluent quality but is designed to cope with the rigours of lifetime service. There are no flimsy partitions to break off if desludging is neglected and the robust polyethylene cylindrical baffle will withstand the impact from even the heaviest desludging hose. This robust two chamber settlement system is designed to BS6297 and carries full BBA approval. Outstanding performance ÿField testing by the University of Abertay, Dundee, showed an average reduction in suspended solids of 82% when installed in a normal domestic situation, giving an average suspended solids level of 61mg/L in the final effluent.
Weiterlesen...
Weiterlesen...
