archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Horizontal Resolution with 540 TV LinesThe SCC-B531x series cameras provide clear 540 TVL images by using Digital Signal Processing. Samsung uses only the Sony Super-HAD CCD, which specializes in the high frequency and horizontal correction signals.Minimum scene illumination of 0.002Lux and Day & NightThe SCC-B531x series camera detects the surrounding illumination environment in real time, and automatically switches the camera to the correct mode, into color in bright conditions, and into B/W mode in low light conditions, so that the camera's DSP can deliver the best image. In addition, it uses Auto Gain Control and Sens-up (Low Speed Shutter) functions together, providing a clear low-noise image.3 Axis Dome Design that Allows Installation on Wall and Sloped SurfaceThe SCC-B531x series camera lens rotates inside its dome and moves up to 340° horizontally and up to 90° vertically. It can be easily installed in difficult areas such as a wall or an inclined surface where it can be difficult to install a surveillance camera.Dynamic CCD Defect Correction FunctionThere are two types of defect correction methods, static correction and dynamic correction. The static correction method corrects the defect when the lens iris is fully closed. It is adjusted only once at the factory prior to shipment. The dynamic correction method corrects the defect each time it occurs by detecting it regardless of the opening of the lens iris. The SCC-B531x camera uses the dynamic correction method, which delivers a more consistent clear image.
Weiterlesen...
Weiterlesen...
