archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Super-low Illumination 0.00001Lux SCC-A2313 allows surveillance under the absolute worst conditions by implementing the super-low illumination through combination of Day&Night and Sense Up functions along with 1/2" IT Ex-view HAD IT CCD and DSP Privacy Protection Function (Privacy Zone Setup) Maximum 24 private zones can be set up to protect privacy and the mosaic method to specify a private area with 4 points makes it possible for users to select the area more accurately. Digital Zoom and Pan/ Tilt Function Digital zoom enables users to identify an object more clearly and Pan/Tilt function allows SCC-A2313 to increase the surveillance area. Horizontal Resolution of 540 TV Lines SCC-A2313 provides clear images with high resolution of 540 TV Lines by applying the DSP which specializes in high frequency and horizontal outline correction. Day & Night Function Optimum surveillance for 24 hours a day is possible through a built-in IR filter that automatically switches to color mode and to blackand-white mode depending on the illumination. Convenient Installation The SCC-A2313 camera adopts the horizontal and vertical mirroring function, providing the correct display of an image regardless of the camera installation environment. Motion Detection Function The alarm is triggered whenever motion is detected in the specified motion detection area set by users.
Weiterlesen...
Weiterlesen...
