archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
As a pioneer in photovoltaic (solar cell) technology and heat pump air conditioning systems, SANYO has consistently taken the lead in research and development in both of these fields. As a result, SANYO has brought together, for the first time, 2 key technologies to create a solar-powered air conditioning system with world-leading efficiency. In line with SANYO's Think GAIA ethos, our solar-powered air conditioning provides an alternative solution that allows you to benefit from the same high level of air conditioning technology and reliability that you would expect from SANYO, as well as using a sustainable energy resource that has no environmental impact and lower running costs. Harness the sun's energy to reduce running costs and CO2 emissions The modular design of the SANYO PV Air Conditioning System means that it can be designed to work with all of our product range, from room air conditioners right through to ECOi VRF. The solar generated electricity combines with normal supply to ensure consistent operation. Also, the solar power can be diverted to other uses so that the energy is not wasted when air conditioning is not being used. SANYO's PV solar cells offer greatly increased efficiency
Weiterlesen...
Weiterlesen...
