archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Ultra luxury sleep systems reserved for the most refined of tastes and the most discriminating of hotels. Internal Components The Stearns & Foster Foam Encased System is comprised of 5 proprietary components that work together to provide an ultra luxurious sleep experience. 1. Foam Encased Top Proprietary layer of foam provides relief from pressure points. 2. Foam Encased Edge A continuous, seamless perimeter of high density, high performance foam that completely surrounds the innerspring system for greater sleep surface and unequaled edge support and stability. 3. Foam Encased Base High quality polyolefin foam base below the innerspring system contains support channels that respond to weight and pressure to absorb energy and dampen motion. 4. Stearns & Foster Innerspring System Made of 123D4 gauge steel, the heaviest in the industry, the innerspring coils are double tempered to maintain memory and shape and are double offset for better hinging and body contouring, to support the body's every curve and movement. 416 coils (Queen), 5T-12 3D4 gauge. 5. UltraSteel Box Spring Patented fully functional box spring amplifies perimeter firmness and extends Comfort Life by deflecting weight from the mattress. 20% more steel provides enhanced strength.
Weiterlesen...
Weiterlesen...
