Roll cap - Roofing panels
archiexpo
12. August 2008
This traditional longitudinal assembly technique involves timber battens and capping strips. The zinc sheets and long zinc strips are held in place by a zinc batten clip supporting the peripheral upstands. The capping strips are placed into position by overlapping, thus ensuring that the roof is watertight. Key advantages Performance: adaptable to complex shapes and roof penetrations Design: expression of strong, conspicuous contours, shadow effects and urban character Easy installation: requires only a simple hand folding tool Easy dismantling in case of repair or maintenance Areas of application All types of roofing, in particular traditional roofs Urban buildings Battens and capping strips Battens: height 40 mm or 50 mm, trapezoidal or rectangular in shape for straight panels, height 60 mm for hip capping and 80 mm for ridges. Capping strips adapted to the size of the batten seam, widths of 100 mm, 120 mm, 140 mm and 166 mm. Accessories Wide range of accessories for all types of roll cap roofs and flashing - Sheet clips for head fixing, batten clips for side fixing, spring clips for capping strips
Weiterlesen...
