archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
MODEL DL3 - MR16 Ring Mount 12 Volt, 50 Watt Max. MR16 Halogen6-24 Volt, 2 Watt MR16 LEDFeatures:-Available with LED or MR16 halogen lamps. Lamp info: LED, MR16. -Precision machined from aluminum or brass with all stainless steel hardware. -Threaded cap allows for tool-less removal, simplifying maintenance in hard to reach locations. -Cap holds up to two lens accessories. -High temperature silicon wire pass-thru and cap O-ring are used to create a completely water tight fixture. -Requires remote transformer. -Available in 14 standard colors as well as several aluminum and brass metal finishes. Click link to view our standard finish selection. -CSA tested & certified to US & Canadian safety standards for use in wet locations.
Weiterlesen...
Weiterlesen...
