RECTOR SOLUTIONS Rector voided floor plate
archiexpo
12. August 2008
The RECTOR voided floor plate is a flooring system that rests directly on the columns and does not require load-bearing beams. It is made up of floor plates overlaid with plastic shells prefabricated in factory. They are designed for receiving a compression table poured on site. Recommended for uniform frames where acoustic considerations are not preponderant, this solution allows covering long spans up to 12.5 metres using elements having a limited self weight.
Weiterlesen...
