Ready to use sail shade
archiexpo
12. August 2008
Our standard DIY SAIL SHADES are manufactured from lock-stitch knitted, UV stabilised, best quality, high density polyethylene and are available in 5 sizes and 4 colours: sizes: a right angled triangle 3mx4m x5m equilateral triangles 3.6mx3.6mx3.6m and 5mx5mx5m squares 3.6mx3.6m and 5mx5m colours: porcelaine desert sand architectural grey forest green Our premade SAIL SHADES are * easy to install and do not require professional installation (see the installation instructions for more details). * suitable for situations where temporary and semi permanent shade is required. * absorb up to 90% of harmful UV rays. * suitable for shading terraces, patios, play areas, outside dining areas and courtyards. * guaranteed for 10 years against deterioration caused by UV rays. * easily cleaned with a hosepipe. * Made from fabric which breathes to significantly reduce the temperature under the sail. * made from UV stabilised commercial grade fabric which gives greater strength and durability. * reinforced with stitched webbing all round the edges, which makes them more stable than any other DIY shade. * Supplied with securely stitched fixation rings made from stainless steel for strength and durability.
Weiterlesen...
