archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The new storage module Quad provides an exceptional modularity, an ultra simplified implementation and multiple uses---Quad is a modular and decorative storage system. It evolves with your needs and changes shape according to your wishes. It combines a very precise minimalist design with finesse and elegance.A bookcase, a night table, a stool, a column of storage, a coffee table, a shop display... The Quad fits together to suit your needs.The basic module of Quad is a perfect cube of 350 mm (13,78 inches) of side. Made from 100% recyclable steel Quad is only 2 mm (0.08 inch) thick. On all sides of the cube, you can easily attach other cubes and design your custom storage system.You can, easily, without tool, change the composition, add or remove cubes. Quad has a clear sculptural value and you can adapt it to virtually any environment, equally suited to a domestic or a commercial setting.Quad is lasercut with no waste in a steel sheet (100% recyclable), folded with precision and lacquered with eco friendly paint. Quad is designed to be durable and multifunctional in the preservation of Nature and Natural Resources.Quad is available in a very trendy range of colors shiny or satin.Gloss Lacquer: blackLove, whitePure, cacaoIntense, redDelicious, pinkParadise.Matt Lacquer: moonDust, powdedCocoa, spiritSilver, chicBeige.Accessories complement the Quad: seat pad, element of closure, link between modules, casters.Length, width, height: 350 mm / 13,78 inches - Weight: 6 kg / 13,23 poundsWhat they said about Quad:“Quad is the Lego™ of contemporary furniture”“They're incredibly thin defying the amount of weight they can carry”“These cubes connect together to infinity, the possibilities are endless”Designer : Dom Trapp
Weiterlesen...
Weiterlesen...
