Providing clean technology and clean
archiexpo
12. August 2008
The laundry industry must adapt to the changing environment. Danube, as a responsible manufacturer, designs and supplies laundry machines saving energy.Large range of washer extractors have been designed to reduce water (in some of the OPL recently installed by Danube, washers need only 7 liters to process one kg of uniform). Reducing water consumption will reduce detergent consumption and with less water and with a high G force (high water removal), drying will be shorter, and again saving energy.Besides saving energy, Danube aim is to reduce the operating cost, by improving the flow and the productivity.To-day Laundry managers, in Hotels or Healthcare, should look at Natural resources and Pollution, before choosing the specifications of the machines, Danube is always pleased to help them in designing integrated competitive solutions.On the other hand, Danube is one of the few manufacturers offering gas heated washer-extractors with built-in heat exchanger.1/FASTER and CLEAN WASHING:Washing linen is based on the “Sinner circle” which is basically the accurate balance between water, detergent and mechanical action.With Danube washers, the degree of mechanical action during the rotating process is so high that it will allow you to reduce water and detergent to a minimum, the processing through moving baths removes so much dirt that wash time will be reduced to a minimum ( different in the hotel industry compared to the healthcare institutions).One of our main innovations beside the design of the machines is the number of programs.Danube controls will allow you a lot of different “wash actions” by sorting the linen , heavily soiled, medium soiling and light soiling, before processing. You will save time and energies , multiple choices of programs will help you.How clean is clean?We know that hotel laundries and healthcare institutions have many potential sources of microbiological contamination, bacteria spread unless stringent controls are in place.Unfortunately, the importance of laundry in fighting infections is often underestimated compared to the controls in place in kitchens, Even in Five Stars Hotels or healthcare institutions, nobody is able to define if the linen is “hygienically clean” free of bacteria or pathogens!It is why Danube R & D department worked for the last several years on sanitary barrier washers especially designed for Healthcare institutions but more and more frequently installed in Five Stars hotels.To-day Five Stars hotels concerned by Hygiene are frequently choosing sanitary barrier design washers.2/ENERGY SAVING when FLATWORK DRYING IRONING:Combination of high technology with the “Smart system” feature which permanently measure the residual moisture of the linen and allows an automatic adjustment of the speed, robust thick cabinet, and efficient heat conductivity because of the thick polished cylinder offer very productive range of Flatwork dryer ironers.Gas heated Flatwork D I.: can be heated very quickly, fresh air is permanently provided to the burners which permit a very low consumption of gasSteam heated Flatwork D.I.: Steam is circulating between two very thick cylinders, the heat conductivity is excellent, and this ironer offers a very stable temperature and a high productivity. Thermal oil can be connected to this range.Electric heated Flatwork D. I.: The flatwork dryer ironer without maintenance. 3/TUMBERS KINDER TO FABRICS: As tumble dryers are key players in the success of on-premises laundry facilities, Danube tumble dryers are equipped with direct drive (frequency inverters) which allow smooth and very quiet operations, standard reverse. The frequency inverter will allow smooth acceleration and deceleration; linen will be dried only and precisely as needed.Shortening drying time will result in energy cost saving, minimal wear of linen and durability of tumble dryers.FOCUS OF DANUBE:Specialist machines meeting end-user's expectations: Clean Linen, high automated productivity, minimum costs, which is minimum energy and maintenance!
Weiterlesen...
