archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The evaporative humidifier increases the humidity of the air, reasonably. The fan inhales the air of the room and thanks to a humid sponge, which filters the air and allows the diffusion of humidity in the air. The minerals and the other components of water stay in the receptacle, the humidity is so perfectly pure. With the professional evaporative air humidifier, furniture, woodworks or other objects of stocks are kept in a healthy climate. MAXIMUM AVAILABLE USE Confort use : 500 m³ Working use : 300 m³ TECHNICALS DATAS : Air filter : yes Humidification at 21°C 30% R.H. 2.5 L/h Color : Anthracit grey Orientable air outlet : yes Manufacturer warrantly : 2 years Air velocity : 2 Air flow : 350 / 800 m³/h Electrical supply : 230 V (Ph+N) with included 2 m cable and plug Control with ajustable hygrostat Wheels 4 Power rating : 53 W Automatic restart after : electrical shut down
ui Sound level at 1 meter : 29 / 42 dBa Water tank capacity : 34 Liters CE Approval : Yes DIMENSIONS AND WEIGHTS Height : 720 mm Width : 625 mm Lenght : 316 mm Weight : 18.8 kg
Weiterlesen...
Weiterlesen...
