Professionnal Evaporative Humidifier
archiexpo
12. August 2008
The evaporative humidifier increases the humidity of the air, reasonably. The fan inhales the air of the room and thanks to a humid sponge, which filters the air and allows the diffusion of humidity in the air.The minerals and the other components of water stay in the receptacle, the humidity is so perfectly pure.With the professional evaporative air humidifier, furniture,woodworks or other objects of stocks are kept in a healthy climate.MAXIMUM AVAILABLE USEConfort use : 500 m³Working use : 300 m³TECHNICALS DATAS :Air filter : yesHumidification at 21°C 30% R.H. 2.5 L/hColor : Anthracit greyOrientable air outlet : yesManufacturer warrantly : 2 yearsAir velocity : 2Air flow : 350 / 800 m³/hElectrical supply : 230 V (Ph+N)with included 2 m cable and plugControl with ajustable hygrostatWheels 4Power rating : 53 WAutomatic restart after : electrical shut down :emoji_open_mouth:uiSound level at 1 meter : 29 / 42 dBaWater tank capacity : 34 LitersCE Approval : YesDIMENSIONS AND WEIGHTSHeight : 720 mmWidth : 625 mmLenght : 316 mmWeight : 18.8 kg
Weiterlesen...
