PP2B Mixed Concrete Wood Floor Beams
archiexpo
12. August 2008
The beams are used as supports of a reinforced concrete compression slab on the spot cast.The connection wood concrete is done by means of metallic cylinders distributed on the upper face of ihe beamDEFINITION-Glued solid wood in Spruce or Douglas-Anti-termite treatment - IF class 2-Metallic connectors assembled - steel tube according to process patented NR 88102559-7 (CSTB 3/05 -443)-Sealing strip (to be positioned in the slotting)-Methodology of patented installation
Weiterlesen...
