archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
They have the aim to support and to brace the covering material. For the stone materials, plates with turned arms, that slip into the countersink of the plate, are used. RL anchorage They have the aim to support and to brace the covering material. They are fixed on the wall without vertical sections. This anchorage allows the regulation of the overhang without intervention on the pallets. Bearing plates They are used to support the profile and to lay it at a distance from the wall, in case it's necessary to increase the distance between the wall and the exterior cladding, for example to insert the thermal insulation.The plates used to lay it at a distance are of different types, according to their specific use: Omega plates Semi- omega plates “S” plates “L” plates
Weiterlesen...
Weiterlesen...
