archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
innovativionThe new self-laying floating floor system PL01 System has revolutionized the traditional installation techniques of ceramic, stone, metallic, wood and glass tiles.patended systemPL01 System is a patented system that permits the laying of tiles without glues, cement, or sealers. It works with a wide range of materials and dimensions.no wait flooringThe flooring is ready right away, so the PL01 System can be installed without interrupting the client's business; during installation there are no odours and no dust.quick installationInstallation time is extremely fast (80 square metres a day with two workmen laying 600 x 600 mm tiles.) This allows the completion of large surfaces in small times reducing operating and manpower costs compared to traditional methods.easy to installThanks to its particular characteristics PL01 System is installed with ease and without the need of highly specialized personnel, guaranteeing a perfect fit every time.on any surfaceIt installs on any surface without ruining it and can even be quickly removed if desired. The installation does not require glues or other joining products that may ruin the underlying surface.on raised floorsPL01 System can be installed on raised floors while remaining inspectable. In fact any tile can be removed when maintenance is needed for any existing systems under the floor.repositionableIt is even possible to move or rotate tiles to change colours or direction of the decorated tiles.resistance to heavy loadsThanks to the combination of steel supports and tiling material, there is no problem for the use of heavy weights.no dilation jointsIn large areas dilation joints are not necessary because the attachment system and the pathlines work together making it easier to calculate total dimensions.
Weiterlesen...
Weiterlesen...
