Photovoltaic Modules By Helios Technology: H/HT Series
archiexpo
12. August 2008
The H/HT Series of Photovoltaic Modules are all manufactured in monocrystalline and multicrystallinesilicon and they are suitable for home systems and other civil applications (cantilever roofs, road signs, hydraulic pumps, telecommunications, etc). It has been created to guarantee maximum and long-lasting effi ciency, with the minimum space required. Thanks to the introduction of the I-Max technology, developed by Helios Technology for its high-effi ciency modules range at the typical battery operating voltage (12,5V), it allow a remarkable increase of the current output (about 10-17%) compared to the traditional modules.The frame of the module is made of anodized aluminum and it is provided with 4 slotted holes, which allow a quick and easy installation of all Helios Technology's modules. Furthermore for an easy installation, Helios Technology's PV modules are equipped with a tin-plated IP65 protection degree junction box, which contains internal bypass diodes and external gable glands (1 for type A and two for type :emoji_sunglasses:, in order to facilitate connections during the installation. Each module of Helios Technology has been designed to resist under the impact of 28 mm diameters hailstones at the speed of 23 m/s (about 84 Km./h) and resistance to a wind pressure of 2400 N/m2 (about 200 Km/h). All Helios Technology's products are CE certifi ed and starting from the H750 module and above, all modules are CEI/ IEC 61215 norms certifi ed by the ESTI (European Solar Test Installation) of JRC (Joint Research Centre). Finally, the models H750 and H1540 are provided with an operative Class II insolation Certifi cation released by TÜV.
Weiterlesen...
