PAR 38 LED Bulb - 12W High Power
archiexpo
12. August 2008
The Par 38 12 Watt 12 LED Spot Lamp has the standard E27 Screw in Base: Installation is Fast and Easy. No modification necessary. Simply unscrew the old energy wasting Incandescent or Compact Fluorescent bulb and screw in the new PAR 38 12 Watt 12 LED energy efficient long life replacement. For the perfect retrofit or new installation, our PAR 38 12 Watt 12 LED Spot Lamps offer an unlimited variety of uses. Uses 12 x 1W high power LEDs. This light is comparable to 120W light bulb. - Luminous Flux: 850 Lumens- Base Type E27: Standard replacement of existing energy draining Incandescent or Compact Fluorescent with no modification.- Beam Angle: 30 Degrees- Body Temperature: Less than 53 degrees Celsius- LED Working Temperature: Less than 62 degree Celsius- Brightness Degradation: 3%-5%/1kh- Life Span: 50,000 hours- Color: Red,Green,Blue,Yellow,Cool white and Warm White- Aluminum Housing- No UV or IR RadiationAPPLICATION:Household Spot Light indoor / outside Entertainment Lighting Architectural Lighting City Beautification Medical lighting Portalbe Lighting
Weiterlesen...
