archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
***DECORATIVE PLYWOOD*** USE: Fitting out of shops and the interior decoration of houses or carrying out of major projects (Media Centres, Conference Centres, Museums, Head Offices, etc…). DESCRIPTION : Plywood made up of peeled tropical woods veneered in strips to a thickness of 0,6 mm on both sides for a decorative effect. 2500 x 1220 / 1530 - 3100 x 1530 mm. Please consult us for other sizes. ***DECORATIVE CHIPBOARD*** USE: Fitting out of shops, interior decoration and the design of furniture. DESCRIPTION : Particle board with an average density of 650 kg / m3 (a mixture of crushed logs, wood shavings and sawdust, to make a compressed mattress used for a panel), veneered on both sides with noble wood species. SIZES: 2500 x1220 / 1530 - 3100 x 1530 / 1830 mm. Please consult us for other sizes. ***DECORATIVE MDF*** USE: Shop fittings, interior decoration and the design of furniture. DESCRIPTION : A panel with an average density of approximately 800 kg / m3 made up of defibred wood glued under great pressure, then veneered to a thickness of 0,6 mm on both surfaces with noble wood species. MDF offers a surface that is perfectly smooth for a high quality finish. SIZES: 3100 x 1830 mm. Please consult us for other sizes.
Weiterlesen...
Weiterlesen...
