OUTDOORCHEF presents his latest gas kettle barbecue: the Paris 570
archiexpo
12. August 2008
The gas kettle barbecue of OUTDOORCHEF represents the perfect symbiosis of function and design.The mobile trolley made of powder-coated steel has four lockable steering rollers which allow flexible mobility. The gas bottle is securely fastened in a special recess in the bottom shelf.Product features and benefits : Lid hinge, spring and lock for ease of use Two separate ring burners for cooking also at low temperatures Bottom shelf with a special recess for the gas bottle Side table in granite Factory assembled gas trains One touch ignition with battery Enamelled: burner, small and large funnels, grid, bowl and lidPackage contentLid hinge Tool holder Thermometer Included: tool kit for easy assemblyGrill surface : 54 cm/2290 cm2Cooking height: 90 cmMax space requirement: 140x66 cmHeat output : 1,2 kW small burner / 8,5 kW big burnerGas consumption : 90 g/h small burner / 612 g/h big burnerGas pressure : 50 mbar
Weiterlesen...
