Ophely air/water heat pump
archiexpo
12. August 2008
This new high performance heat pump collects the heat from the outside air and can heat the whole of your home at minimum cost.You can even cool your home in summer or heat your swimming pool. The water heat exchanger is the most compact of its type and can be installed easily in a garage to provide heating for the whole house.It can supply :Underfloor heating Low temperature radiators Fan blown radiators The heat pump is installed outdoors. The inverter drive technology enables the heat pump to operate efficiently down to outside temperatures of -20°C Ophely heat pumps are reversible and can also be used to cool your home in summer. This is only possible if you install underfloor heating/cooling and/or fan blown radiators.A heater can be installed to heat the water in your swimming pool at very little additional cost. The inverter drive enables the heat pump to reach a coefficient of performance (COP) of 4,5, one of the best on the market. For 1 kWh of electricity consumed, the system produces 4,5 kWh of heat : 3.5 kW additional heating is provided free compared with standard electric heating. Using Ophely heat pumps produces up to 83% less CO2 per year.
Weiterlesen...
