archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
CDVI offers a wide range of online access control which gives a full flexibility in both price and performance.2 to 128-Door controller- 2 doors (2 readers)- 2500 cardholders and 3000 assets- 8 inputs and 4 relay outputs- All doors are opened in case of emergency- Client server architecture- 500 events- Real time calendar and clock- Holiday's functions- Interlock and airlock feature- Non-volatile memory- Utilises low costs CAT5 UTP or Belden cabling- 8 inputs/4 relay outputs- Access control and time management reporting- ODBC compliant database- Plug & Play installation compatible- RS232, USB & TCP/IP connectivity to associatedistributed intelligence cardholders- Door alarm monitoring- Mains and battery failure low messages (LT20ACversion only)- Input voltage : 12V DC- Consumption : 560 mA- Power supply with charger (battery not included)- Main power monitored- Battery monitored- Metal box temperedTWO DOOR UNIT IN A METAL CASE DimensionsWidth (mm): 282 Height (mm): 297 Depth (mm): 78
Weiterlesen...
Weiterlesen...
