archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Even this time EURAPO, leader on the production of water terminal units, aimed on news:EURAPO aim his attention at the customer satisfaction.The innovative thermoregulator OMNIBUS solved elegantly every applicative situation connected the easily use with a wide function availability.The most interesting point is that this system invented by EURAPO could grow based on the dimension and characteristic of the system.The system present an own flexibility employment, based on few elements, easy to install and intuitive on configuration and use.There are different type of remote console: from the simple Analogue control, to the elegant and complete Display control, to the Infrared control.An accurate planning made possible the realization of a product with a particular and elegant design: Omnibus could be configured based on the different customer requirement with extreme facility and allow a weekly and seasonal planning of all the functions.The Omnibus digital system is designed to manage and control the water terminal unit (fan coil units, water cassette units and high pressure ducted fan coil units) for domestic use, residential buildings, public rooms, moreover Omnibus could be integrated with BMS (Building Management System).Omnibus is a supervisor for small system connected via MODBUS RTU and it can manage one or all of the units in the system at the same time via Web Server (suitable with Internet Explorer 6.xx).The OCB20 converter permits to connect 10 water terminal unit; it gives information about the units to the Lonmark net and it receives information from the Lon net.
Weiterlesen...
Weiterlesen...
