archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Overall standard cubicle height: 2000mm with 150mm floor clearance. Framework: Full aluminium frame. Extruded satin anodised headrail and vertical posts, with integral full height door closing buffer. Door: 30mm lightweight MDF core, edged first, and faced with specified finish. Pivots from headrail encapsulating concealed hydraulic door closer, with anti finger trap clearance on pivot side. Divider: 16mm high-density chipboard core, edged first, and faced with specified finish. Supported on engineered 304 grade stainless steel foot. Fittings: Engineered 304 grade spring-loaded stainless steel lock, with concealed fixing through door and emergency release facility. Lock locates into stainless steel receiver, integral to the aluminium framework. Full aluminium frame Door suspended from headrail 32mm thick door Concealed hydraulic door closer, tested to 1.5 ton Stainless steel fittings Spring loaded polished stainless steel lock Machined stainless steel receiver. Emergency release Available in veneer, glass and stainless steel 10 year guarantee
Weiterlesen...
Weiterlesen...
