Notts Sport ‘Brightons Up The Play' With Money-Saving Refurbishment Advice
archiexpo
12. August 2008
Existing sports grounds can be given a new lease of life by Notts Sport – and recycling the old is all part of the company's philosophy of giving its clients a great value for money service.One such example can be seen at Hove Park in Brighton, where the leading synthetic surfacing supplier was able to provide expert advice on refurbishing five tennis courts that had endured years of play.Following a detailed inspection of the original surface installed some 16 years earlier, Brighton & Hove City Council was advised that the most cost-effective solution wasn't to be found in replacing the entire system.Instead Notts Sport's distributor, S & C Slatter, carried out minor re-leveling work to the underlying ground, re-used the original shockpad layer which was showing little sign of wear, and replaced the top carpet with a new VHAF NottsSward TS surface.Shaun Patrick, Chief Executive of Notts Sport, explains: “The VHAF NottsSward TS tennis surface is different from other sand-filled artificial turf because the unique random structure of the fibres stabilises the sand and makes it less likely to compact...........
Weiterlesen...
