archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Movinord's new partition , Nodux®, is characterised by innovation, transparency and light. The innovation of Nodux lies in the material used: high-impact, transparent Polymethyl methacrylate PMMA profiling; innovation in the intersection parts: Nodux® joint technology; and innovation in the extensions to the system: fully-integrated courtesy signage and lighting. Features of the Nodux® partition High transparency: not only of the panels, but also the frame which holds them: polymethyl methacrylate, which is highly transparent and does not yellow. Exclusive, innovative design: pure, straight lines. Perfect finish: the technology of the Nodux® joints allows for 90º-angle cuts and ensures a perfect finish. Other advantages of the new Nodux® partition Easy to assemble, dismantle and transport: due to the simplicity of the assembly system and the lightweight elements which comprise the frame. Rigidity: because the panes are well secured, reinforcement profiles are employed and the maximum thickness of the glass is 12 mm. Flexibility: partition by elements, demountable and reusable. Extensions and accessories unique in the market, such as the decorative lighting totally integrated into the partition. Wide range of formats using different glass thicknesses and different types of joint between panes. Coloured panes can be used as an alternative to blind partitions to visually isolate different areas. These consist of two panes of glass with a sheet of coloured PVB in between, maintaining the overall appearance in terms of shine, texture, uniformity and flatness. Courtesy signage and lighting totally integrated into the system.
Weiterlesen...
Weiterlesen...
