New series of the brine to water heat pump from STIEBEL ELTRON
archiexpo
12. August 2008
WPF E and WPF cool are impressive The new WPF E/cool series of heat pumps from STIEBEL ELTRON is convincing with the integrated, high-efficiency circulation pumps and a high level of integration. Apart from standard components like the heat pump control unit, safety devices and heat pump assembly, a brine pressure expansion vessel, a heating pressure expansion vessel, two high-efficiency circulation pumps, a changeover valve for the supply of hot water and hoses for decoupling vibrations for the heat pump from the heating circuit have already been integrated. This saves the engineer fitting the heat pump many stages of work and as a result both material and time. As the integral components all match each other, operational safety is improved and potential errors in installation are ruled out from the start. Thanks to the integrated high-efficiency pumps, both on the brine and the heating side, it is possible to increase the efficiency of the heating system even further. The low rate of power consumption by the pumps in use ensures a substantial improvement in the annual performance factor. Another new feature is the high-quality design. It has strikingly clean and distinct lines. The ergonomic arrangement of the user panel with the retractable control box underneath makes operation ideal for all types of users and ensures that installation is quick and without complications. The casing for the hydraulic lines that is additionally included in standard delivery is also new and makes sure that insulation is clean and professional. Transport aids at the rear of the appliance make it easy to move the heat pump. The new brine to water heat pump is available in two versions: as an E version for heating and domestic hot water and as a cool version for cooling, heating and domestic hot water. In the cool series the additional plate heat exchanger required for passive cooling has already been integrated. Metering the amount of heat and electricity in accordance with the German government's Market Stimulation Programme (MAP) is taken care of by the integrated heat pump controller. Innovative technology, a high standard of workmanship and distinct design are plus factors which make the new WPF E and WPF cool series of heat pumps stand out from the rest.
Weiterlesen...
