archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
New range of automatism for Telescopic DoorsAprimatic has created the new series PZ Mounted separable mechanical assembly and electrical wiring. The DC motor has an encoder and dual-channel double toothed belt drive friction coated neoprene.The cars have three sliding wheels mounted on ball bearings and antidescarrilamiento system. The battery pack is standard. The bistable electric lock with double anchoring of the car is optional. The PZ series has five operating modes selectable from selector (SC6 Evo), or 12 programmable settings 25 parameters configurable by optional programmer.Functional features:Self-study:Stroke length.Speed (depending on the weight of the leaves).Speed braking (separate adjustment between opening and closing).Braking area.Selector functions:Closed.Automatic.Open (with possibility of manual movement).Automatic single output.Automatic with partial opening.User Security:E-crushPower limitation.Entry for closure presence sensors.Entry for opening protection.Interconnectivity with smoke detection systems, fire alarms, etc..Entry EMERGENCY multifunction (6 different settings).Battery (7 different usage modes).Security against intrusion:Electric lock (optional)Lockout leaves.Automatic closing if tampering.Diagnosis:16 alarms with audible and the display of the programmer.Technical Data:Crossbar Dimensions: Height 175 x width 234 mm.Max. per sheet: 75 kg (monolateral) and 50 kg (bilateral). (1)Vano minimum pitch: 800 mm (monolateral) and 1,300 mm (bilateral).Vain to step up: 3000 mm.Supply voltage 230 V A.C. - 50 HzPower consumption 200 VAType of continuous employmentOpening speed 40-70 cm / s (monolateral) and 80-140 cm / s (bilateral)Closing speed 25-40 cm / s (monolateral) and 50-80 cm / s (bilateral)Voltage by 24 V external accessories D.C. 1 A max.Operating temperature -10 ° C ~ 50 ° C(1) Bilateral: sliding table leaves. Two move to the right and two to the left.Monolateral: Two sliding panels to the same side.
Weiterlesen...
Weiterlesen...
