archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Kinesis, the Arcadia intuition for modern offices, thanks to a careful technical development this is a vanguard product. Winding legs that can be tilted in two ways, straight or inboard. Just as you need.The practical Kinesis table, excellent part in addition to directional office for quickly briefings. Smooth shape and soft color, every aspect is studied to merge together into the modern office.The Element eclecticism whom compose a perfect mix with Kristal. From operative to excecutive with some litle changes. Kinesis, functionality and sinergy in every aspect.Take up to revamp and propose in a new and high-tech way. With the equipped bar, now Kinesis, makes dynamic what is always been considerated static. In multiple composition the desktops are sliding forward, to improve an easier settlement of cables. The equipped bar can be applied both in single or multiple compositions. Its greater detail is the sliding track, where you can put accessories like glass panel or melaminic panel, holders, lamps. The same concept of moving is in force on singles desk. Channeling is entrusted to the wide sliding basket, in this way you can position and inspect the cables in any time. Kinesis is full compatible with the environmen, even the smallesdetails are studied to integrate in this Arcadia project: two spaces for separate waste collection.Modesty panels with custom fi nishing can slide on the alluminium bar thanks to the special staves, moreoverthey can be dressed with metallic round to support magnetic-post-it.The drawer-leg with bearing function: extreme original and unbelievably practical thank to its very small cluttered.
Weiterlesen...
Weiterlesen...
