NEW !! Floor Automatic - Bread slicing machine
archiexpo
12. August 2008
- Machine fully automated- Equipped with a variable speed display-8 slicing speed- Safety cover with automatic opening.- Innovative design, silent.- Ideal machine for perfect use in your in your bakery-storeAll machines are in conformability with CE NORMS.All parts are the same for all machines (frames-pusher-fibre comb)All models are available in 400/450/500 and 600; each machine can be customized according to your own specifications. (Except the New mini and Mini only in400/450 mm of width)Self –adjustable to accommodate a wide variety of breads up to a maximum length of 38cmsThickness of slice: 9/10/11/12/14/15/18/20/24/25/30mmOur speciality: The DOUBBLE SLICES for example: 10+12.5 mm/10+ 15mm/12.5+18mm.Complete with packaging for sacking for easy enclosure of sliced loafBody in steel of 5 mm thickness (LACDH)Stainless steel – guaranty in quality alimentary: ref 316/304Robust machines with attractive designBlades replaceable when blunt (only 20 mints for change blades)Motor possibility 220 mono/ or 220 TRI or 380 TRI / 440 TRI/50 or 60 HzSpecial Key for blades change-- drawing and technical documentation with each machineDelivery time for usual models: 8 days ex-worksColour: White: RAL 9001. Possibility to obtain other colour, all is possible in ref: RALWARRANTY / 2 years on parts
Weiterlesen...
