archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
NARBE' kitchen is made of cabinets of marine plywood veneered with natural Zebrano wood. The doors, the finger grooves and the panels are built using a single veneer which is fire-branded on the back with numbers in order to reconstruct the vein. This system makes result a design which is always unique, that only nature itself can produce. The countertop is made of green Corian, chosen among 100 chromatic versions. The backsplash is an integral part of the top and has end extensions that fit perfectly into the side panels. The innovative solution assures hygiene and harmony of shapes. The sink is of stainless steel and it is integrated to the top and closed by sliding tempered-glass panels which create a single surface and increase the working space. The internal drawers have sides of stainless steel and are furnished of soft-motion opening system which allows an easier and silent opening. Each part of a Toffini kitchen can be customized through the use of exclusive Toffini fittings.
Weiterlesen...
Weiterlesen...
