archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
For technically demanding applications, such as building cellars or flat roofs, the insulation materials used must not only be able to take pressure loads, they must be resistant to moisture, water and salty or acidic soils. In such cases, URSA XPS is the obvious choice. This extruded polystyrene rigid foam offers excellent compression strength, a high level of heat insulation and low water intake. It is easily handled, cost-effective and easy to work with under any weather conditions.URSA XPS ensures a low heating demand in buildings and helps to relieve the strain on the environment. What's more, the production of the insulation material itself is environmentally friendly, since it is foamed with naturally occurring gasses.
Weiterlesen...
Weiterlesen...
