Montecarlo: an original shape for urban lighting
archiexpo
12. August 2008
Urban space is an asset. This is the reason why landscaping is getting increasingly accurate and differentiated in parks and gardens. Fountains, benches and lamps mark the boundaries of car and frenzy-free zones. The use of urban lighting is constantly evolving. Today, the focus is mostly on the lighting effects achieved, along with the sensations that a place where lighting has been renovated can arouse. Top quality results are achieved using high-tech products and excellent design to supply the quantity of light needed and desired. In other words, these are solid, powerful and highly directional products characterized by excellent design features, just like the range of Disano products.Lighting is a major plus point of urban decor, based on two main reasons:- design- the opportunity to use light beams in the best way possibleWhy Montecarlo Its design evokes the city of the future, representing a light distribution solution designed to spread light over wider areas, without losing light skyward.The luminaire complies with anti-light pollution regulations.Montecarlo is a versatile lighting fixture designed to meet different requirements, as external environments are becoming increasingly characterized by different uses.Montecarlo offers manifold mounting solutions and can also be customized through different colours.Technical specifications:- Die-cast aluminium housing - Anti-condensation air recycle valve - Double insulation - Tool-free maintenance - Optics: different optics for different requirements - Striking design and colour customisation- Available in the suspension and pole top mounted version, also with brackets, for outdoor and special indoor lighting requirements- The special shape of the optics also makes Montecarlo suitable for use as a top-mounted luminaire in the centre of the road, with light beams pointing to the four corners- Old city centres often require specific lighting systems for suspension mounted installations- Poles are not required in the correct position - Floodlights cannot be mounted on ‘ancient façades' - Supplied with wire - Tradition
Weiterlesen...
