Mistral - Heater
archiexpo
12. August 2008
MATERIAL: steelTHE PRICE INCLUDES: standard elementTO BE ORDERED SEPARATELY: exhaust valve, reduction cap,attachment bracketsFINISH- white RAL 9010- colour chart Scirocco HHYDRAULIC ATTACHMENTS- hydraulic installation diagrams• standard: same side• on request:both can be positioned down low with tube centre-line distance L+ 100 mmSIDE WALL INSTALLATION: possible with floor supportsTECHNICAL NOTES- how to place your order - valves and holders - maximum working pressure: 10 bar- electrically welded steel elements (thickness: tubes 1,5 mm, heads 1,25 mm), attachments 1” 1/4 G- maximum temperature of water: 96°C- with one bank you can add another group of elements using threaded fittings- the radiator is a single electrically welded block and therefore no elements can be removed.- available for single tube installation
Weiterlesen...
