archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Scope High quality MDF with customisable 3D surface. Suitable for interior decoration and furniture production. Description Standard high-density MDF with hard and smooth 3D surface. Suitable for industrial processing for interior decoration and furniture production. MDF Design is produced with high-density MDF made of 100% softwood and has no coarse fibres in the surface. The board is also very easy to mill and has low formaldehyde emission (E1 class). Use of the product The board must be applied in service class 1 (restrictions in temperature and ambient humidity) and can only be used in biological hazard class 1 of EN 335-3. The boards must be protected from any direct contact with water. They must be stacked flat, on a pallet or using a sufficient number of cross members. Boards should not be stored vertically, unless ground contact can be avoided. The board will expand or shrink under variable humidity conditions. Use suitable sawing, milling and drilling tools. Depending on the application, MDF Design can also be requested in all available MDF qualities from the Spanolux Stock list (moisture resistant/ fire retardant/ low formaldehyde mdf or powder coating quality).
Weiterlesen...
Weiterlesen...
