archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The prince of comfort The Maradja electric radiator combines a cast iron heating element with new technology (heating diffuser film) to produce the effect of old-style heating while responding to the modern demands for comfort and design. * Output: from 750 to 2000 W * Models: Horizontal, Low, Vertical, Horizontal Deco * Cast iron heating element + heating diffuser film on the front panel * Comfort: - gentle, continuous and homogenous heat from the front panel (permanent hot spot) - reacts rapidly to temperature changes * Design: elegant design * Convenience: - easily accessible thermostat discretely placed on the upper end of the device - measurement of the room temperature, dialogue with the device - ASP (Anti-Fouling Process) - heating indicator light * Controlled power: depending on heating needs, only 25% of the power is used (heating diffuser film) * Safety: - double insulation - over-temperature cut-out device - lockable commands with flap * Economy: electronic thermostat and Pass Program programming kit * Precision: digital electronic thermostat * 6 setting modes pilot wire: Comfort, Comfort 1°C, Comfort -2°C, Economy, Frost-free, Stop (load shedding)
Weiterlesen...
Weiterlesen...
