archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The MAC 301 Wash™ is an LED moving head washlight with a powerfully fast zoom and impressive zoom range. It is capable of producing a wide range of exceptional colors from rich saturated shades to pastels through the entire zoom range. LED-based MAC with zoom The MAC 301 Wash's efficient and fast zoom provides beam angle control from 13 - 36° for more accurate and flexible design possibilities. The fixture's outstanding RGB color mixing is maintained through the entire zoom range. Optics The MAC 301 Wash's 108 high-power LEDs produce a bright and well-defined beam – the brightest LED moving head in its class. The LEDs are arrayed in a high density design to enable a more even blending of colors. The innovative and highly efficient lens system makes for a punchy beam with great beam definition. Outstanding color A principal feature of the MAC 301 Wash is its excellent RGB color mixing system. The full spectrum system combines with the unique optical system to produce a wide range of vibrant saturated colors and subtle pastels. A range of mixed shades from cool to warm is also possible. For increased color possibilities, the MAC 301 includes an electronic 7 color + white color wheel rotation effect with snap, blackout or dimmer fade at each color change. Dynamic effects The MAC 301 Wash is capable of smooth dimming from 0-100% with excellent color stability throughout the dimming range. Strobe effects such as pulse and random effects are also possible. Movement High-speed 450° pan and 332° tilt movement with fast acceleration and smooth movement is provided by powerful three-phase stepper motors, all while staying surprisingly quiet which makes the MAC 301 Wash suitable for noise-sensitive applications. An automatic positioning correction system returns the fixture to its original position should it be accidentally knocked out of position. Control The MAC 301 Wash is industry standard DMX-512 controllable with stand-alone and synchronized master/slave options. It is equipped with both 3-pin and 5-pin XLR connections. An illuminated graphics display provides for easy programming and easy-to-read fixture menus and messages. An auto-sensing power supply covers worldwide voltages and frequencies allowing the fixture to operate anywhere in the world. Design Made of durable discast aluminum, the MAC 301 Wash's compact, lightweight design makes it ideal for rental applications, television use, night-time venues and more. The fixture's head and yolk are easy to access for easy cleaning and maintenance. All the benefits of LED The MAC 301 Wash offers all the benefits of LED technology like greater reliability, less maintenance and increased energy efficiency for a lower cost of ownership. Fast and efficient zoom: 13 - 36° Brightest LED moving head in its class Excellent color mixing for vibrant saturates and subtle pastels Punchy beam with great beam definition Smooth electronic dimming: 0 - 100% Electronic strobe with pulse and random effects Compact and low weight Quiet DMX-512 control All the benefits of LED
Weiterlesen...
Weiterlesen...
