Lode E Serie - Wall Mounted Water Heater With Sealed Chamber For Indoor Use
archiexpo
12. August 2008
The gas-fired, wall-mounted LODE E water heater, with sealed combustion chamber and forced draught , is a high-performance boiler. Thanks to its exclusive features, this water heater is capable of supplying DHW quickly, by using two heating sources: the semi-accumulation inside the water heater and the instantaneous supply of water.This system has many advantages:A higher hot water supply , which allows the supply of hot water in various situations, such as the opening of new taps. The quick supply of domestic hot water: hot water comes directly from the tap and is always available. The supply of hot water is guaranteed even in winter and in mountain areas, with very cold inlet water The LODE E water heater can work even at very low water pressures. LODE E water heater can supply a great quantity of domestic hot water for various services, such as big Jacuzzis. In this case it is recommended to use the LODE E water heater combined with the B70 storage water heater .Installation : indoors Supply: methane gas or LPG Thermal efficiency = 90% Certifications: EC certificate under approval Norms: manufactured according to the following European Directives:73/23/EEC (Low Voltage)89/336/EEC (Electromagnetic Compatibility)90/396/EEC (Gas)
Weiterlesen...
