archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Easy to Install The LiteTouch Neo is a conventionally wired Wall Box system with units capable of controlling as many as eight independent dimming or switching loads from a 4-gang box. The LiteTouch Neo is installed using standard Cat5 cable and mounts into standard electrical boxes. Easy to Program LiteTouch Neo is easily programmed from the built-in programming panel located on the face of the unit. Create the perfect mood by selecting any of the seven standard switch types available on the LiteTouch Neo Controller. No external connection, added software or computer required. Easy to Customize The LiteTouch Neo comes equipped with customizable options. Independently set fade-on, fade-off and ramp rates. Also choose any of six available LED colors and add optional custom engraved buttons to suit any user's need. Easy to Upgrade The unique LiteTouch Neo Cartridge technology means that LiteTouch Neo has room to grow. More loads can be easily added. (LiteTouch Neo4 controls up to 8!) Higher-wattage fixtures can also be easily added. Upgrading a LiteTouch Neo to control additional loads is as simple as adding more Cartridges. Each Cartridge controls a separate lighting load, has its own microprocessor, and automatically recognizes and communicates with new Cartridges added to the system. Easy to Use The LiteTouch Neo offers one large main button for intuitive control of a room. Each LiteTouch Neo includes default engraved button caps which allow for clear identification of button function. Further enhance the system by replacing button caps with custom engraving. Easy to Integrate Add the LiteTouch Neo Remote IR Receiver to the LiteTouch Neo controller to be able to control the lights from any remote control, touch screen or whole home system. "Easy Chair" Access Utilize a LiteTouch Neo IR Remote for easy control of lighting. Each LiteTouch Neo Remote automatically mimics the programmed functions of the Litetouch Neo. Easy to Link Each LiteTouch Neo automatically recognizes and communicates with new units introduced into the system. Up to 32 LiteTouch Neo4, Neo3 and Neo2 units can be linked in any combination into a networked system to create system-wide control of lighting loads. Add up to 8 accessory keypads to each LiteTouch Neo4, Neo3 and Neo2 unit to accommodate multi-entrance and 3-way applications for easy on/off. Accessories include LiteTouch Neo1, LiteTouch Neo4 Mimic and LiteTouch Neo 3-Way.
Weiterlesen...
Weiterlesen...
