Kya small and elegant!
archiexpo
12. August 2008
KYA is the staircase designed for the smallest spaces. It is created with varnished steel supports in black (RAL 9017), white (RAL 9010) or grey (RAL 9006), with black finishes for the black staircase and grey finishes for the grey or white staircases. Characterized by light (natural) or dark tinted solid beech treads, which are carefully shaped and staggered, this staircase allows the maximum accessibility with the minimum use of space.The railing is composed of varnished steel balusters and stainless steel cables running parallel to the handrail.The wood-effect handrail is in PVC with an aluminum core and is available in light or dark versions, to match the shade of the treads.KYA has an adjustable height between 228 and 282 cm.By purchasing certain supplementary items, the staircase height can reach 329 cm.
Weiterlesen...
