archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The K-Tronic Locks are a quick retrofit for keyed cam locks supplied as standard on a wide range of lockers, cabinets and cupboards. It can just as easily be fitted to units which don't have a locking device already fitted, giving the user immediate, Simple, keypad access without the hassle of keys! The K-tronic is a stylish electronic Cabinet Lock - ideal for use on cupboards, cabinets & lockers. New 10 button keypad User Codes are 4 digits long Master and Sub-Master Codes are 8 digits long Multiple User Code mode One Time User Code mode (locker mode) 15,000 openings on 2 x AAA cells (supplied) Battery failure override using 9v battery accross LED's (+/-) and Master Code Easy to fit in a matter of minutes All parts / fixings / template included Quick retrofit for cam locks Fit to units that do not have an existing lock Easy programming and code change Door thickness: 1-19mm Cam fixing point: 8mm Spindle cut out: 16mm diameter Body material: Zamac Batteries: 2 x AAA cells (supplied) Finishes: Silver Grey
Weiterlesen...
Weiterlesen...
