archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
To guarantee the highest level of performances for the all-purpose oven operators, Doyon has engineered a unique series of ovens. Our Jet Air Plus Oven Series recreates an environment of hot air movement and humidity first in its class. Delicate foods and everyday items come out quality perfect. The all-new Jet Air Plus is an all-in-one cooking oven that will cook, bake, roast and rethermalize. Use it with convection heat alone or with convection heat and humidity combined. Shot steam (one injection) or pulse steam (constant steam injection) is accurate and will provide the results expected. Doyon is proud to have perfected a direct steam injection system creating moisture without a boiler. Years of development helped us to built units that will last for years for heavy use with minimal maintenance costs. Our Jet Air patented reversing fan system will guarantee uniform cooking and baking without turning pans, allowing the operators to save on energy costs and labour time. Be confident to partner up with Doyon in your day to day operations. The Jet Air Plus Oven Series is definitely suited for the all-purpose cooking, baking, roasting and rethermalizing. Keep ahead of the competition with the most economical and reliable ovens on the market. OVERALL DIMENSIONS 38 1/8" W X 35 1/8" D X 28 1/2" H (969 mm X 892 mm X 725 mm) Shelf spacing: 4 1/2" (114 mm) Features Manual mode and user friendly programmable control up to 99 recipes Up to 10 steps per recipe Temperature range from 150 °F to 500 °F (66 °C to 260 °C) Digital temperature display adjustable in °C or °F Patented reversing fan system Unique shot and pulse steam injection Cool touch door with dual thermal wide view glass windows, swings open for cleaning Door locking position at 120° Door handle for one-handed operation Door with "swing close" function Side loading pans Halogen lights All-around insulation Zero clearance side and back, 4" bottom and 12" top Press-fit removable door gasket for easy replacement Lift up removable side racks Soft cold water connection facility located at the back of the unit Height adjustable legs for tabletop units Stainless steel inside and outside Low-noise high-performance 1/2 HP motor Cord and plug connection One year parts and labor limited warranty
Weiterlesen...
Weiterlesen...
