invisio
archiexpo
12. August 2008
Trimo added a novelty to the existing, well-established construction systems - panels with hidden fixing or Trimoterm INVISIO, which enables performance of vertical façades. Façade system combines aesthetical accomplishment with excellent technical characteristics. Simplicity and fast assembly stand out among the properties. Fixing of INVISIO panels is performed by optimised washing elements and self-cutting bolts. All fixing elements are integrated in a panel joint and they are not visible after the assembly. The range of application is extremely wide since these panels are suitable for representative, commercial, business and industrial facilities.Panel form and fixing method are made to hide the fixing spots. Sheet metal on the external side can be made in micro-lined or stair-like form, the internal sheet metal in stair-like or »v« form.
Weiterlesen...
