archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
1. With the application of the latest technological LED chips, this LED strip offers many kinds of light color changing modes: static state light color change mode: R. G. B. Y. W etc. which is same as the normal RGB LED strips; dynamic state light color change mode: chasing, floating, glittering, jumping, which has many especial mode different with traditional RGB light strip . 2. Max Control length by one controller : 200 M ( no need any amplifier between the ribbon) 3. Used 5060 TOP SMD RGB; 4. 150 PCS LED/Rell(5M); 5. Input voltage DC 12V; 6. Can be cut by every 3 LEDs and connect again with our accessories 7. Can be change into waterproof with type A (with hollow silicon tube )and type B (used silicon tube and glue inside ) 8. Size: L 5M X W 12MM;
Weiterlesen...
Weiterlesen...
