archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
LEISTRITZ meets your needs by offering the ideal solution when a residential lift is required. This lift is a hydro solution that epitomizes all those elements required for use in maisonettes or even in workspaces, with low shaft pit depths. Absolutely fit for disabled or wheelchair using individuals due to the large dimensions of cabins and doors. Max number of stops: 4 Max rated load: 450 kg Low electricity consumption (2 - 2.5 kW) Operating also with single phase motor (220 V - 50 Hz)
Weiterlesen...
Weiterlesen...
