Home Swim Spa made of superior fiberglass construction
archiexpo
12. August 2008
SwimEx Swim Spas use a paddlewheel to create a broad smooth water current that is as wide as the pool and from 18” to 30” deep depending on the model Our unique design allows for a non-turbulent exercise environment and the water resistance level is fully adjustable with 99 speed settings.The 500-OS and 500-S swim spas are made of superior fiberglass construction with a water depth of 50 inches (127cm) and hold 2600 gallons (9841 l) of water. These models utilize “side channels” as a water return system enabling a greater water depth and faster counter-current pool water speeds. These side channels include 2 built in seats on each side to allow for exercise or relaxation. The optional jet package places 3 jets behind each seat. The pool counter-current extends 18 inches (46cm) deep with the standard 5-hp drive system. A swimming arrow, running platform and a 10-inch (25.5cm) front step are standard, increasing the diversity and application of this swimspa. Add the optional integrated underwater treadmill to further enhance the versatility of the 500-OS pool. The 500-OS home swim spa is a one piece construction design, and the 500-S swim spa is a four piece pool. For tighter areas an eight piece design is also available.STANDARD FEATURES One-piece fiberglass swimming pool construction Built-in molded seats - two on each side Filtration system (5.5-kw electric heater, 3/4-hp pump, 75-square foot (22.86 square meter) cartridge filter) Air operated swimmer controls (stop/start & fast/slow) Rear emergency shut-off bar Non-skid floor surface Electronic controller - converts 208-240v single phase to 3 phase Pre-installed inlet and outlet fittings Stainless steel electropolished front and rear grates 5-hp electric motor with paddlewheel drive system Recessed steps with stainless steel handrails Two stainless steel front handrails Swim arrow with choice of color Running platform & front step exercise packagePOOL SPECS Pool Size: 7'7” x 17'8” x 4'10” (2.31m x 5.38m x 1.47m) Pit Size: 12' x 20' x 4'10” (3.66m x 6.1m x 1.47m) Pool Weight with equipment: 3,200 lbs (1,451kg) Pool Volume: 2600 gal (9841 l) Pool Filled Weight: 25,000 lbs (1,133kg) Load Bearing: 425lbs sq.ft. (2074.31 kg/m2)
Weiterlesen...
