Home Automation from Futronix. Leader in intelligent lighting
archiexpo
12. August 2008
For switching loads like fluorescent ballasts, non-dim loads and curtain/drape motors. Features high capacity plug-in relays for easy maintenance, and double changeover contacts for dual-motor curtains and drapes. Inputs and outputs are easily configurable according to function. Relays can be switched independently, or as part of a scene, an event or a macro. 5Amp @ 240V AC - 10Amp @ 120V ACaccepts Digital Logic level inputs from Futronix controllersadjustable voltage triggering for switching fluorescent ballastscan be used for switching power rail in conjunction with 1-10 converter card.pulse switching for operating switches on AV equipmentsynchronisation compares a logic level input 0-5v from otherequipment with the selected level, and switches accordinglyswitches double changeover contacts for dual-motor curtains and drapes.Loads such as fluorescent ballasts can be switched ON or OFF at a pre-set point in the dimming curve. Mimics a switch-press for controlling AV & air conditioning equipment that requires a pulse contact closure of variable duration. Comparison-switching, where switching only takes place when a logic level input from AV/ air conditioning equipment doesnâ™t match the required input from a Futronix controller, can be used with pulse switching.
Weiterlesen...
