archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
This high power 6W LED spot light is our new borned and promoted hot product,in the base of 3W LED spotlight,Model ENRL-3P3WMR16-03 . But this new one is for higher replacement of 50W hologen. This 6W MR16 Spotlight, with 28 and 60 degree beam angle for choices, can be used in different location for different replacement purpose. And we also supply E27 and GU10 base. Presently,high power E27 spot light are widely used,but high power MR16 Spotlight are not used very ofen. As more and more people are pouring into the world of LED illuminationl,people has more requirements when using LED lights. This new 6W MR16 will help to take a new vision on the LED illumination with its widely accetpted appreance,high efficiency and eco-friendly. Datasheet: Cree LEDs. High brightness and long life, reliable performance. Replacement bulbs for common lighting LED quantity: 3PCS of 2w high power CREE LED Colour: Warm white and cool white is most popular Base: MR16/GU10/E27 base are available Light intensity: 320 lumens Beam angle: 38 or 60degree Supply voltage: VAC11-18 Life time: 50000hours Aluminum body with good heat sink Direct replace the halogen MR16 35-50W
Weiterlesen...
Weiterlesen...
