archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Launched 1-Feburary-2009 - The RECTANGLE is the 2nd fire in the new CVO GEOMETRIX™ range of gas fires. A set of five specially designed fires all with unique design shapes and technology characteristics. Designed by one of the fireplace industries top designers with the quality and style you expect from CVO Fire. The RECTANGLE has European wide CE approval for many different gas categories and is very easy to install. The RECTANGLE is supplied as a complete "Hole in the Wall" suite with integral burner, enclosure and fascia. Designed with minimum depth (330mm) to allow installation into both new and old properties. Suitable for Class 2 Flue systems and above. The RECTANGLE has been designed by one of the industries top designers with sleek modern lines and perfect geometric shape. All aspects are created from rectangles. The complete fireplace suite is created from high quality Brushed Stainless Steel and incorporates cutting edge burner technology with a beautiful flame unrivalled anywhere in the industry. The "Rectangle" shaped burner creates shimmering flames and a sea of crisp sparkles. CVO Fire has been at the forefront of gas fire and fireplace design since 1999. Specialising in using high specification technology and cutting edge lifestyle design practices to create very unique and desirable gas fires & fireplaces. All CVO Gas fires are CE approved for use with Natural Gas or LPG (Propane) and can be supplied throughout Europe. Modern, Contemporary Fire Designs : At CVO we have one of the largest ranges of CE approved Gas Fire Burners units within Europe. Many of our Gas Fire Burners have won awards for Beauty, Style and Technology. We pride ourselves on designing fireplaces which provide a stunning design feature within a property. Choose from our standard range of fireplaces as there are many design styles and material options available. CVO Fires have been installed in both Commercial and Domestic properties around the World. Included within this range are our Flueless [no chimney] gas fires which do not require a galss front and have a large open flame.
Weiterlesen...
Weiterlesen...
